I have a 2K Boxster with the Tiptronic trans and need to adjust the cable length. I have located where the shifter cable is attached to the trans and have freed up the adjustment lock nut. My question is do you rotate the actual cable or rotate the end that is attached to the bracket, if so how do you remove the cable from the bracket?
Edited by Iam1320b4u
