can someone please help me!!! I've got a 996 turbo 2002 with a bose system in it. i have replace the cdr23 with a kenwood dnx7200 but i get no sound out of it. I've noticed a connector with two leads in it i think it is for the bus fibre optic system. how would i go about bypassing the fibre optic system
The fiber optic MOST system was started in 2003 models, although it is possible yours may have it if it's a late 2002. How did you connect the Kenwood? Did you use a harness? Are you trying to use the factory Bose amp, an aftermarket amp, or are you connecting your Kenwood directly to the speakers?
