I have been hearing a noise which sounded like a bad bearing for the past week or so therefore, I removed the ribbed belt in hopes of finding the source. Upon turning the tensioning roller, I found it to be loose on its axis and making a grinding noise on spinning. All of the other items, ie. alternator, A/C compressor, etc. appear to be fine.
Am I correct to assume that the tension roller needs to be changed?
If so, how do I do this? Do I simply turn the 24mm bolt counter-clockwise to remove the mechanism or is there more to it?
How much should I expect to pay for this item at my local dealer? I'd rather have an idea before getting ripped off without fair warning ....
2003 996 non-turbo
Edited by 2Fast996
Anybody??? :huh:
2003 996 non-turbo
Sorry, can't answer your question as to whether you should change it. However, here's a diagram of how the roller attaches. To remove, you turn it counter-clockwise while countering on the bolt it is mounted on.
Good luck!
