:huh: I bought my 03 S a few years back and there has been a clunk noise in the drivers side front end sinse day one. It hapens at low speeds when making a right hand turn over small bumps. I have to hit the bump with my driver side wheel. 2 shops have looked at it and both found nothing. The battery is bolted down and so is the spare wheel. Maby its a bad shock? Could I swap the two fronts (left to right and right to left)? Has any one else seen this problem? Thanks for any help you can offer. :)
Could simply be a slightly loose swaybar droplink mount. Check that the droplink is torqued correctly on the swaybar.
You can find how to do that here: http://gwl.rmsolo.org/hacks/suspension/index.html
To answer your original question, yes you can simply swap struts left to right, they are identical.
Good Luck,
Graeme
Good Luck,
Graeme
Graeme, Thanks for your resonse.
I'll check the swaybar first.
Scott
