According to the Porsche Tech Manual... Yes, they can be machined.
Here are the specs (Carrera only, GT3 specs are different):
Brake disc thickness, new -- front 28 mm, rear 24 mm
Minimum brake disc thickness after machining* -- front 26.6 mm, rear 22.6 mm (* The brake disc must only be reworked symmetrically, i.e. from both sides evenly.)
Brake disc wear limit -- front 26.0 mm, rear 22.0 mm
Peak-to-valley surface roughness of the brake disc after machining, max. -- 0.006 mm
Thickness tolerance of the brake discs, max. -- 0.02 mm
Lateral runout of the brake disc, max. -- 0.03 mm
Lateral runout of the wheel hub, max. -- 0.03 mm
Lateral runout of the brake disc when installed, max. -- 0.06 mm
