Key Remote failed, Aftermarket system?
Well, my remote has stopped working (tried all the tricks, ie flipping the battery, pressing unlock while in the key hole), and nothing has worked. So i was thinking, why not jsut get a complete new alarm system (lock/unlocking, and remote starter) for the car. Has anyone done this? Does this work? My key to the car still works and i called my dealer, he was like, "200 dollars for the key and another 60 for programming." So for 260 dollars, can't I just get a new alarm system. As always, thanks for the input.
When you speak with Sunset, be clear that you do NOT need a new key shaft (the only reason the replacement should cost your quoted $200 would be for a shaft and key head).
I paid approximately $75 on ebay for a key head to put on my old shaft. If you go this way, be sure you buy only a head that includes the bar code tag.
In Atlanta, I paid less than $50 to have 2 keys mated to the car (its the car that is programmed, not the keys). Took about 10 minutes.
