Hi-My 97 boxster (40K miles) has a random "won't start problem. The key turns ,isn't sticky or hard to remove, the dash lights come on and after turning the key once or twice will crank and start.
This is what I have done so far:
Jumpered out the clutch switch-
Changed out the ignition switch (Audi Part).
Things went well for a few weeks and it is happening again?
I have another new switch but looking for ideas before doing it again.
Thanks Chuck
Thanks Chuck
If the engine won't even turn, I would still suspect ignition switch.
Good luck!
Toby
