I have a 2000 996 with PCM1 Nav. I replaced the broken CD player (CDC-3) with another one (CDC-3). I now get 'No CD Player'. Is the CDC-3 a plug and play device or do I have to re-initialize the PCM system and enter all the codes.
Gerry
It really should be 'plug and play' especially with no MOST. Are you sure the connections are OK?? Is the CD-3 a known working unit?? If so, try taking off the battery for a few minutes and try again. Make sure you have the PCM codes though before you do! ;-) Key in the ignition to stop the alarm going off too.
