Loren, in the rear brake DIY, do the instructions incorrectly state that the 30mm vibration damper should be in inserted in the top piston, or am i just misunderstanding where the top piston is (I assumed the top piston was the piston located near the top of the caliper).
Thanks in advance...
David
At this point I'm not sure I remember... last car I did (before the DIY) was a Turbo and I can't remember if it was different or not.
The larger one (30 mm) will only fit in one place so that should tell you for sure. Let me know what you find...
Hahahah, the larger one fits on the bottom then. I spent almost an hour trying to fit a square peg into a round hole Sat night, as the instructions read "make sure you get the right size into the right spot..." Anyways, it worked well the other way, it may be worth updating the DIY sheet.
