More work going on....so another part number request.
I have the shocks/springs for my RoW M030 kit, ordering the sways and the bushings for the sway linkage that will allow the M030 sway to fit in existing link. Sunset couldn't confirm correct P/N for the rear as there were apparently a few options.
1) Does anyone have the correct part number for rear sway bar bushing that can accomodate RoW 030 sway bar?
2) Does anyone know the diameter of the M030 rear sway? Sunset can verify correct part number if I had the rear sway bar diameter.
Thanks again!
Edited by bk12
PS. My understanding is the the X74, and US M030 kit use the same sway bars as the RoW M030...so if anyone has a diameter measurement on the rear sway for any of those packages, it would help me out a lot.
Thanks again!
These are the part numbers off the ROW 030 Kit from my 2002 Carrera 4 6 Speed Cab.
996.333.792.25 qty 2 Stabilizer Bar Bushing (Front)
996.333.792.12 qty 2 Stabilizer Bar Bushing (Rear)
996.333.701.26 qty 1 Stabilizer Bar (Front)
996.343.703.04 qty 1 Stabilizer Bar (Rear)
Please check to verify the coupe, tip, per-02 might have different part numbers for the sway bars.
Thanks for that info.
I re-searched (umpteenth time on this topic) and found mention of sway bar diameter for the kit in an old post of Lorens...missed it the other times. The rear sway is 19.6mm, and the front is 23.6mm. I will try to get the P/N for the C2 when I order and post them for future reference.
