Hi I have an early 987S without the TMC working.
I believe i need a PCM update to achieve this.
Ive got some update discs now.
What is the procedure to update it?
Update the navigation system using a map DVD from 2005 onwards and the TMC functions as a facility of the newer map. If you have an older map version (2004) then you first need to update the navigation system using the update CD's before you can use the 2005 or later map.
