Anyone out there with a ghl exhaust? I was wondering if there is anything that can be done to decrease/reduce the amount of resonance that is produced in the lower rpm range... i guess you can put a resonator on it... would changing out the tips decrease the sound or is it all from the muffler??
Search this over on ppbb.com. Someone over there found a motorcycle resonator (maybe HD??) that they fixed into the tips that they said worked wonders.
I think they are drag pipe inserts, but I know someone who installed them on their GHL, but it also didn't help much. I think with the GHL, you have to a) either learn to live with the resonance, B) keep it above 3K rpms, or c) wear ear plugs when you drive. :D
