Does it really work?
After extensive research, apparently DMS is the best "chip" for a Cayenne turbo but I can get a good deal on GIAC. so if any CTT owner who has GIAC flash on their cars could share their experience would be great!
What sort of quater mile time should be expecting from my CTT after a chip?
While we are at it, whats your launch technique? Press the gas pedal as soon as green light? or launch at certain revs if the ecu allows it? How do I turn traction control off? What tyre pressure to use on 20inch wheels? and etc...
Cheers
looking for similar info. i've found some feedback on other forums [run google search]. in listen mode...
chad
Cheers
which other forums do you find useful?
Rennlist seems quiet for Cayenne discussions. 6speedonline has a little more Cayenne activities than both here and Rennlist.
panameras, yes, agree with your thoughts below... have you looked at upsolute tune? price is much better than giac, pros and cons are listed on 6speedonline...
chad
