Has anyone figured out how to retrofit a 997 homelink to a GT3?
What I found out was that the homelink module is in the front end and runs around $500, and is not a reasonable mod to attempt. It seems more worth while to use the porsche homelink switches and hard wire in the transponders that come with the garage door opener behind the map light dome area above the mirror.
Has anyone actually tried this? Are there instructions or diagrams?
I got the initial info here homelink mod
However, I am going to try to retrofit this 996 idea using the 997 homelink switches:
996 garage door mod
