Hello.
I have installed a Raptor shift light, and am having some problems. Installation manual can be seen here:
http://www.raptorperformance.com/INSTRUCTI..._revisionD_.pdf
I have tried all of the various settings, and it lights up at different rpms depending on whuch gear I am in (6-speed, 2002 S). I know that my tach signal wire that this is connected to works properly as my GPS reads the rpms correctly from this wire.
How is our ignitions set up? I believe that we have one coil per cylinder, but does it fire multiple times per rotation?
Anyone else had problems / success with a shift light? I bought this one because I was looking for a small enclosure, as I don't like the huge shift light looks.
Thanks in advance,
Paul
Sounds to me like you didn't set the shift light for a 6 cyl car. Most of them have wires you have to snip so it knows if it's a 4-6 or 8 cyl. Have you done anything in particular to the light so it knows how many cylinders you have? That affects the tach-o output from the computer and it will get 50% more or less readings if your in the wrong mode.
Edited by 986Jim
Is has a 3-way toggle setup to tell it the number of cylinders, and I did that. It didn't work, and neither did any other combination (I tried them all).
Anyone have a shift light in use on a 986?
