I need help! I'm halfway through PSE install (mufflers only) and stuck! Following Loren's DIY and doing one side at a time, I've removed the old muffler and the new one is mounted and the exhaust tip in installed (loosely), but I can't get the new muffler connected to the cat pipe. Is there some kind of spreader I can use to open up the cat pipe just a fraction??
Mark
'99 996 coupe
The muffler pipe does not go into the cat pipe they are joined by the cat sleeve (4). Your kit should have had new sleeves. If not then you will need to loosen the sleeve bolts and spread the sleeves (not the pipes).
Loren,
My explanation was poorly worded. I was trying to figure out how to expand the cat sleeve. But I'll check to see if I have a brand new one and let you guys know.
Thanks in advance for all the help.
Mark
