Checking Vacuum
According to the troubleshooting in the OBD II manual you are starting at the end.
Here is the troubleshooting they suggest:
Secondary air injection pump is not triggered.
Secondary air injection pump does not work.
Air supply lines restricted.
Electric change-over valve does not work.
Air change-over valve does not work.
Vacuum system leaks.
Here is what they suggest recommend for solutions:
- Wiring harness or fuse
- Relay
- DME control module
- Air supply lines
- Secondary air injection pump
- Electric change-over valve
- Air change-over valve
