Are the differences between the 997 Navigation and Extended Navigation System software or hardware based?
(e.g. If I purchase a 997 with the regular Nav can I upgrade to the Extended nav via software?)
It is a software upgrade and can be done by an OPC. An interesting fact is that from Aug 07 production all PCM systems will come with Extended Nav as standard.
I thought it was an additional module on the PCM also?
No more than 10 minutes work without a test drive. But Porsche allows the dealer 40 minutes without and 70 minutes with.
Half a shirt or a full shirt off your back..... check your dealers hourly rates.
