Would you guys recommend against installing an Aero Cup Wing without the rest of the kit? I am thinking about installing just the wing on my MY00 C2 for now, and considering the side skirts and front spoiler later. Will having just the wing (without the rest of the kit) significantly impact the handling, performance, and safety of the car at high speeds?
The 99-01 996 had a minor problem with front end lift at high speeds. Before adding the aero front end, mine would start moving around a bit at 145 (on the track) and get worse from there. That was without a rear wing which would have made it much worse. The aero front end settles the car down perfectly. I think this is one area where you should listen to Porsche. I would not consider adding a rear wing without the front if you intend to drive the car at significant speeds.
If $$ is an issue I would add the front and sides first and go for the wing later.
hey denik,
I've seen lots of cars that only have the AeroKit wing on Porsche Centers parking-lot even though it is only in combination with the GT3 front (w/o spoiler flaps) according to German TÜV!
and for the MY00 model, I total agree w/ JimB proposal about the front and the sideskirts!
cheers,
Tony
Does anyone make a lip spoiler for the front of the car or does the whole bumper cover need to be changed? (01 C2 Cab)
I don't know where the original information was obtained from but the info below was posted recently, in this forum I think. I don't know what model year this refers to. The facelifted one I guess if Jim has had noticeable problems at 145mph...
Here is a little trivia for you about how even the "little" stock wing on the carreras impacts the just the lift aspect of aerodinamics (996 carrera):
Wing down
Front lift (at 157mph) --> 64 kg
Rear lift (at 157mph) --> 136 kg
Wing up
Front lift (at 157mph) --> 5 kg
Rear lift (at 157mph) --> 14 kg
BTW:
GT3 rear lift at 200km/h (124mph) --> 0Kg
GT2 rear lift at 200km/h (124mph) --> -8Kg
do the figures apply to any particular suspension set up? just wondered as I assume the amount of air going under the car is different if lowered???
hey ffelan,
do you mean something like this?
if that is the case, I think most of the tuner have those in their product portfolio.
the one in the picture is coming from Cargraphic
they are also active in the GTP Race weekend, cool guys.
cheers,
Tony
that's just a lip, add-on to the original 996 or GT3 front!
on the pic, it's a GT3 front and on the normal 996 looks more or less the same but not as lowered as on the pic, but definitive better look.
cheers,
Tony
Are we talking racing speeds here? For a car not tracked I do not think it would be
significant. BTW Does attaching lip spoilers, as opposed to entire bumper cover replacements, cause enoough down force?
JimD
Yeah I doubt within normal speeds that you can drive on roads within most countries (especially the US) that you'll notice much problems. I've heard the problems occur with lift starting at 120mph+ speeds. Personally, I would wait till you can buy the full kit as the painting would be smarter to be done as one unit using the same paint for consistency.
I agree 100% with Adam... paint consistency is very important especially if color is one of the more difficult ones to match
JimD
