Probably a dumb question but I figured id put it out there. Is there any way to adapt the big red rotors/calipers from an 06 Carrera S onto a 99 C4? If so what parts would be needed?
There’s never a dumb question. I know this question has been asked many times. Use the search feature. The short answer is yes you can but, it will cost plenty and some would question why. The stock brakes work very good for street use and there are easy way to improve your braking for track use i.e. new/better fluid, change pads and upgrade to GT3 brake cooling ducts.
