Hi Folks,
First, thanks to the RennTech crew and community for a great website and forum. It has been a tremendous resource in pre-purchase research.
My question... New to me 99 C2 Cab, US 6-speed. Previous owner had new brake pads installed about 300 miles ago, but left the old rotors in. Rotors are at or below min thickness and heavily scored. I will be replacing the rotors this week. Should the newish pads be replaced as well? I assume they have taken on the profile of the rotors' scoring and wonder if this will invite uneven wear on the new rotors?
I think you are going to have to look at the pads to determine whether they can be reused. If there are deep scores already then I wouldn't reuse them.
With both new rotors and used (or new pads) you will have some bedding in to do. Maybe a little longer with used pads.
Hi Folks,
With heavy scoring, reusing the current pads will create a difference in the amount of stopping power on each side during the break-in period. Under heavy braking, your car could even pull to one side depending on how significant the scoring is/was from side-to-side. You can do it, but there is some risk involved.
