I'm having a hard time removing the wire connector clip from the MAF sensor. Is there a clip release? Do I use a screw driver. I tried pulling it off but that didn't work.
How did you guys do it?
No screwdriver.
On your year car there should be be two tabs that squeeze on each side of the connector.
Dunca! Loren
