I'm trying the Dension install on my 2007 987S.
How do you get through the firewall from the battery area to inside the cabin? Anyone done this?
tmc
I had the dealer do my install ( was worried about warranty issues ) and we decided that the ipod didn't need to be inside the car ... I bought a second ipod to use on my boat & when travelling, at home etc., so the ipod in the Porsche resides right next to the cd changer & is only accessed when I need to do a sync to update. This has worked out fine & was a much easier install.
There are a couple of full pictured write ups over on the caymannet forum of the dension gateway and ice link install on a 987C (cayman)
Yeah that's good, thanks.
I'm installing the bluetooth interface and leaving the mic in the trunk would make for awkward phone calling, to say the least.
tmc
I went through the rubber grommet that Loren specified when I need to run wires to the front, should not be a warranty issue either.
BTW, post back when you get the Dension installed, I would like to know what the sound quality is like... Is this with or without a PCM system?
To the right of the battery, on the firewall, is a rubber plug. Cut an X in it and pass the wires through.
Worked like a charm. I had read elsewhere you needed to remove the battery, but you really don't. If you have a fish tape (standard electricians' tool), it is a piece of cake. A bent wire hanger might even work.
