Anybody know a quick hack so I can use my fogs for DRL's? If I can, I might convert them to zenon.
That's answer I would like to know too.
:unsure:
  • 10 months later...
Look hereDRL Hack
That's old news......I've done that and that's for the headlights......I want to use the fogs as DRL's.....
Im based in the UK, so not familiar with e DRL. But elaborate a little more and I will scan the electric blue prints for a way round what you require.
...............elaborate a little more...........
Thanks........I would like to install a single independent switch (in a switched circuit - off when the ignition is off)
that would let me light the fogs independently with no other lights turned on.......Just like the aforementioned
DRL headlamp hack, but using the fog lights instead.
OK guys,this should be very easy & simple
Since U wanted to add a switch in a swiched circuit ,all you have to do is by-pass(throw 1more toggle) the switched leg
1.pull SI A7 25AMP fuse out
2.diassemble/remove light switch assembly
3.run a pair of BLK/RED 16 AWG wires from new switch location
4.locate NSE contact(switch assembly), tap/splice BLK wire with VIOLET factory wire - this will be the ignition switched
primary power source
5.locate N contact, there should be a YELLOW/WHITE factory wire needs to be disengaged from the switch assembly +
tap/splice RED wire with YE/WH factory wire - this is the switched leg feeding 2 front fogs
6.mount new switch tapped with BLK/RED wire
7.finished
Edited by juniinc
Any time fan,,,
it wouldn't hurt meter those wires with a 12V tester - Violet should come on only with the ignition on & Yellow/WH should come on with the fog swithch on.
Good luck!
