2002 Boxster S
I was working on installing my new amps in the front trunk, so I had the carpet and plastic guards off.
Now, the ABS light is on. I tried to unplug the battery, to no avail.
The ONLY thing that I did was to add a looped wire end to one of negatives of the ABS system to ground the amp. When I noticed the light, I removed the extra loop end to see if that was the problem. That didn't help.
I looked to see if there was any loose wiring, but I don't see any. I guess it COULD be a coincidence, but not likely. This has never been a problem before, and once I was near it, now the light.
Any ideas?
