Hello there...I was wondering if there is a way to make the roof of a carrera cabrio to open auto with one touch,like front windows...And to close as well...Also I tried to do a mod about the rear windows to close when the roof is down,but no success so far...I jumpered the switch on the front side of the roof so to make the rear windows operate...The problem is that when I tryied to close the roof,there was no response...I ll try something else tomorrow...
  • 4 weeks later...
Get a relay with a built in timer. You wire the relay to send a negative pulse to the open\close wires of your car. You can use the arm trigger from you remote or connect directly to the switch. You time how long it takes for your roof to open\close and set the relay for that time. You will need one relay for open and one for close. They are about $20 each.
If you would help on how to wire the relays and the wires colors for your car let me know and I can provide them.
