Hellol all,
I have a newly acquired '98 Boxster (2.5L, standard, silver) and this is my first post.
First of all I read and learned a lot on this forum already - great community! I already implemented the garage door opener mod and it works great! No more bulky openers hanging on the mirror...
(I also changed the headlight bulb as one of them was dead, but that was a piece of cake).
My Boxster came with the owner's manual, however it is molded and the pages are stuck together to the point that I can't open them at all (previous owner left the books in the rain or something), so I can't really read the manual unless I get it off of eBay or something similar. My questions are:
1) Can I download the manual somewhere or can I look at it on the web in PDF / HTML / whatever format?
2) While I wait for a manual suggestion, what is the deal with the rear wing on this year model (98)? Is it popping out at 70 + MPH by itself? Can I leave it out all the time or manually control it? If so - how?
Thank you all very much in advance!
If the 1998 is similar to the 2002 model the answers to your 2nd question is:
A ) Yes the wing "pops out" when you drive faster than 120 km/h (somewhere around 75 MPH) and retracts when you slow down to under 80 km/h (50 MPH)
B ) Yes. You can manually control it to stay out. On the 2002 model there is a button down on the left side in front of the drivers doors. (Just below the connection where you can hook up a battery to open the trunk and hood when the cars battery is flat)
/Stuntman Mike - Boxer 2002
Hellol all,
Edited by Stuntman Mike
Thank you Stuntman Mike - I will look for that button when I get out of work, although I don't remember seeing one...
:welcome: Azzar0
Mike is correct :thumbup: .
Tail pops out automatically at 75 m/h and hides at 50 m/h. You can manually move it via a button located on the bottom of the fuse cover located in the left side of drivers' footwell.
Good luck with your car :cheers: , and ALWAYS :drive: DRIVE SAFE!
BDB._
You can download a PDF Owner 's manual on this site (under "Quick Menu/Porsche Owner's Manual) but it is for a facelift Boxster (post 2003?) which has a few minor differences from your model (has gloveboax etc.)
Thanks - downloading MY00 manual now. The differences are minor and I can ignore them.
Thanks again!
:welcome: Azzar0
BDB._
BDB - thanks for the description of the location - I couldn't find the button. I will look at the fuse box later today.
I downloaded the manual and found the button as well. The wing slides out and back in as it should. COOL :)
Thanks again guys!
Thanks again guys!
Enjoy the car :D
Edited by Tom C
