In an effort not to bugger up my stock shifter housing (while trying the SSK) I want
to buy a second housing to muck with. I've found a 5-speed and I wonder if it
is basically the same unit as the 6-speed (the housing, not the shifter).
I imagine I could check the parts catalog but I thought someone might have some
quick, direct knowledge of this.
thanks,
S.
2001 Boxster S
5 speed is the same as the 6 speed except the 5 speed has the green platte. If you remove the green plate from a 5 speed housing then it is a 6 speed housing.
Don't spend the time or $ on a second housing - just find a local member who has a SSK and try it out. You'll either love or hate it (love most likely) w/in a minute or two. I, like you, was worried and bought a second housing as I didn't know any local 986 owners (at the time) w/ a SSK . Needless to say, when I installed my SSK, the OEM shifter housing went on eBay the very next day.
BTW, if you don't love the SSK in a 986, then you might look for an OEM 987 (or 997) shift housing (a few on eBay right now). I've heard some say it's a nice step in between the OEM and a SSK in the 986 - food for thought I suppose.
