Sorry guys if this is not a new topic but I could not find it in the forum but I tried. The detailed problem description is as follows:
- When passenger door handle is opened (from either side), the window does not increment down as intended
- Manual use of the window switch has to be performed to prevent glass banging on cabrio trim when closing pass door
- Window motor is functional and will even stop at partial closed condition when door is opened (latched)
Other pertinent info:
- Was recently in body shop for unrelated damage to front fascia by GIANT Racoon
- When cabrio switch is used all window operations appears normal during cabrio retraction
- Noticed wet carpet on pass side rear footwell (may be related if Body Control module in vicinity) - plan to clear water path at rear wheel well as recommended from other posting :renntech:
- Already disconnected battery and reconnected to attempt to "hard-reset" any electronic control unit
- Ordered Durametric and will try to acquire any DTCs if arrives by this weekend
- When I pull on door handle, I hear a switch engage but no movement of the window
My questions are:
- What detects that the door is being opened that initiates the window retraction, where is it?
- What do I need to do to have access to this sensor to inspect and/or replace?
- Where is the Body control module that takes this input? Or is the there a Smart Module in the door that communicates to a body security module via CAN messages?
- Or am I SOL and need to take it to the dealer for $125/hr to troubleshoot?
I'm new so please take it easy on me......
Sounds like the microswitch in the door handle is bad.
I'm having same issue on a '99 C2 Coupe on drivers side. I can see it start to drop occasionaly but not consistently and only a few millimeters when handle opened. Passenger side drops roughly 1/4-3/8 inch. Good news (I think) rather than being an issue with the window motor. Is the microswitch replacement a DIY project? I'm reasonably handy and just put in B&M SSK this weekend with no difficulties.
Dave
Dino
I go for the door latch, the switch witch is build in the latch self is faulty. The signal lock open is missing.
Thanks Loren for the quick reply.
How do you get access to the microswitch?
I checked on the part at the dealer: $45USD It will take 3 days to arrive.
I just went throught the exact same issue with the exact symptoms on a 2002 C4S. I think you have a bad window regulator. I paid about $500 installed.
Well, Ordered a microswitch from sunset porsche to fix the intermittent problem with drivers window but while waiting for it to ship, the window began making grinding noises then became stuck in up position and quit working entirely. I coughed up the bucks at my local dealership for a new window regulator ($220 + tax) thinking that may have been the entire problem. Well, just over 2 hours later, I had the regulators switched out (the old one had a cable that was snapped) and window works great including the drop down feature when handle is lifted! So I think the intermittent drop down malfunction was the initial sign of the bad regulator. Can't say that I enjoyed dropping the $ but had a great time with the DIY project and the $200-300 savings in labor. :renntech:
