We have a '98 2.5 Boxster that suddenly developed an engine coolant leak. Investigation reveals that one of the radiators has "burst" - looks like the internal pressure got too high. Question, is the filler cap (mine is blue) solid or is it supposed to have a pressure relief function? If solid, is there pressure relief elsewhere in the system please?
Yes the filler cap have a pressure relief function.
Thanks RFM - seemed that it should. Now I just need to work out how the pressure got high enough to burst the rad.
Are you sure it burst ? All 911 and boxsters suffer radiator corrosion from leaves and debris building up on the bottom part of the rad. Could it be it simply rotted through to a point where the rad popped ?
As mentioned above, the front rads on these cars collect leaves which rot leading to leaks.
If you are worried about over-pressure, yes check the coolant cap, but also get the air in the coolant header tank 'sniffed' to test for cylinder head gasket leaks (after the engine has been run for a bit).
On my old VW Golf VR6, the heater matrix deep in the dash blew apart (fun - not) because the head gasket had gone and was forcing combustion pressure into the cooling circuit.
Jules
