Finally found how to launch, simple put the car on drive with left foot press hard on the brakes at the same time floor the gas with right foot and watch the boost come up, now it is up to you when you want to take off simply by letting go of the brake pedal.
Edited by Loren
Removed ALL CAPS
What do you think the DME does with a closed brake switch and a full throttle ?
