I have a 996tt with k24 turbos, i was getting 0,8- 1 boost readings . Now for some reason my max reading is 0,4 . Any suggestion what to check for?
Can it be i am driving with just one turbo?
did you upgrade your DVs? Could be that one of them is bad. Or perhaps a boost leak somewhere else.
No new DVs . Any ideas where to look at?
I would take it to the dealer. If they find that the DVs are bad, you should buy some aftermarket billet ones. I got mine from evoms (www.evoms.com). The stock DVs are weak and are known to fail.
