My engine has developed a noise on the right bank when it's cold. It sounds like a lifter noise, but I'm not sure. The noise goes away after the car warms-up. Car has about 10K mi. on it and about 4 months left on the warranty.
Does anybody have any ideas what the problem might be?
By "after the car warms-up" do you mean 2 minutes or 15 minutes?
If it disappears after 2 minutes then that is normal. If it takes much longer it is likely a stuck lifter.
Thanks Loren.
It goes away in about 5-8 min. Then, everything is fine. It only does this once in awhile, especially if the car has not been started in a week or so.
