I bought the Durametric Diagnostic tool and found the following fault codes:
Airbag:
C152 Meldung timeout PSM
PAS:
8004 Versorgunsspannung Klemme 50
8005 Versorgunsspannung Klemme S
8053 Electronic steering column lock
What does all this mean? Should I take my car to the dealer?
2007 Boxster S (987)
Thanks.
Rob
Do you have any lights (airbag) or other problems?
If not, I would double check with the folks at Durametric. Could be Porsche did an update they are not aware of...
Only if you want them to charge you a half hour of labor to clear them. These are garbage faults probably left over from the PDI process.
