Hi, I recently came into possession of a '99 Boxster Conv. While repairing the broken top mechanism I noticed a bolt on the driver's side, located right above the lower ball joint for the cable that secures the top in the rear is loose (normally it is under the insulation, but I pulled it back while removing the ball joint.)
What is this bolt and should I be concernced?
:renntech:
Edited by dfellars77
