I have a my02 targa. The shade switch works and moves the front bar back and forth to "open & close" the shade. The problem is that when it goes back the shade does not retract and roll up into the back like it should. Instead it just droops down. I pulled the cover off hoping it was just a spring loaded mech and stuck. But after looking at it, it may have a second motor to roll up with. Has anyone had this issue before? I was able to roll it by hand and at least it is out of the way now.
Any help would be appreciated.
A motor is used to open the shade but its pure spring tension that closes it. Targa roof work is a complete motherfu(@er and if I was you I would pay some one else to hassle with it.
Sounds like it has lost it's tension. As I recall when it is installed they wind up a tensioning spring.
Does the motor run?
The motor runs and it will roll back and forth no problem. The issue is that when it rolld it back the remaining shade material does not roll into the cover it just droops down. I will look at it and see if its a spring. If not I will bring it to the stealer.
