Anyone know if a 2002 996 TT Front Rotors/Caliper will fit the 987 Boxster? What other parts do I need to make it work or it's a definite no go?
I know the boxster S is basically the as the 996 narrow body rotors/caliper but red, but what about the TT caliper/rotors?
I have a base boxster
The part numbers are
Front left caliper: 996 351 429 10
Front right caliper: 996 351 430 10
Edited by NYSpeedRacer84
In a nutshell, the caliper bolt spacing is different and not adaptable. So, you will have to change out the wheel carriers and a whole lot of other stuff--I think to the tune of $2K--not including labor or the brakes at which point you should just get the GT3 brakes. Now if you had PCCB, that would be a different story as far as fit, but then you wouldn't be asking to fit TT brakes.
Recommendations really depend on why you want to upgrade.
