Guys i need your help again just installed gt3 wing and bought the wiring harness to deactivate the auto wing. now i noticed that my blower fans direction is blowing in the air is this normal? or its supposed to blow the hot air out? my temp now is close to 100 degrees.. pls guys help thnx in advance:)
100 C or F?
100 C is too hot.
You should check and clean your front radiators. Also, check you coolant tank and make sure it is full and not leaking.
100 C or F?
100 C is too hot.
Ok loren i would do that thanks a lot your a life saver! :)
