The remote/key to my 2002 Boxster suddenly no longer operates. The battery's fine, it seems; the red diode light blinks brightly as usual when either of the 3 buttons are pushed but no locks are activated. I key-open the door, quickly insert the key in the ignition, hoping to reactivate the codes, but nothing. How did this suddenly go wrong? I'd appreciate any helpful suggestions as to what to do next. Thank you.
The car came with 2 remotes. If you have the other remote try it. If it works then reverse the battery for a few seconds in the remote that does not work. If it still does not work then you have a bad remote.
