I have an 2001S and the other day I opened the passenger door. The
window rolled down 1/2 way (HUH???). So I got in and started the car and
tried to roll the window up, but instead it rolled all the way down and won't
roll up. I tried to disconnect the battery to see if I just needed to reset the
window, but no dice. Anyone have some suggestions or had this happen?
The driver's side window is functioning correctly. Also, I tried unlatching
the soft top to see if it would roll up when I latched it, but also no luck.
Again the driver's side window worked OK. Are there different fuses for
each window or are they on the same fuse?
Before you dig too deep and start removing door panels, try the easy stuff first, it could always be a bad switch. It's very easy to remove the console plate that has your window switches in it. Since the driver's side window works fine, disconnect your driver's side window switch, then move the passenger side wiring connection from the passenger window switch to the driver's window switch. Now use the driver's window switch, and see if you have any luck.
OK, I had a chance to try interchanging the window
switches on the center consol and no go. The switch is not
the problem. I also don't know if my problem has anything
to do with the window stops. Remember my window was up
all the way and when I opened the door, it should have rolled down
alittle, but rolled down approx 1/3 of the way. When I
started up the car and tried to rolll it up, it rolled down the
rest of the way. So I don't think it is the window motor, but
maybe the regulator? Anyone have the info for doing that
fix? By the way I can't see any pics on the old threads, only
red Xs.
I cannot get the passenger window to roll up from
the full down possition to even try to retrain/reset the
window. Also, When I tried to roll the window up after
it had rolled down 1/3 of the way, the up button on
the window switch ended up rolling the it down the rest
of the way instead of rolling it in the up direction. This
is whay I not suspecting the motor, but something
electrical. I did check all the fuses, even though the
front windows are on the same fuse and since the
driver's side works, would indicate that's not the
problem.
The window is stuck in the full down position so it
doesn't react to the door handle at all right now.
Does anyone have pics of replacing the window
regulator? Where to purchase one, at the dealer?
Mr Tool Pants or Loren, Can I get an assist in
doing the install? I've never taken apart oe of the
Bpxster doors yet. I now live close to San Thomas
and El Camino in Santa Clara.
OK, So I fixed the window. I went and got a new regulator
and motor from the dealer ($500). I wasn't sure if I would
need them but I wanted to have them when I opened the
door up. From the great instructions from Tygre, I removed
the motor and regulator. I seperated the motor and reconnected
it to the connector and tried it. It worked just fine. Also, The
regulator looked OK too. So I put it back together and mounted
it back in the door and tried it to make sure it still worked. Lo
and Behold, it worked. So I put everything back together and
reset the windows and all is well. So I guessing it had a glitch
when the window rolled down 1/3 of the way and defaulted
to the full down position when I tried to roll it up. So in effect
all I needed to do is give it a kick (so to speak). Anyway I
took the parts back and the problem solved with a few hours
of labor. At least I'll know what to do next time there is a
door window problem. Again thanks for your help Loren.
