Okay,
I just got my box back from the shop and decided to install the spinlocks. I got the fittings in and everything, but I have one problem. I cannot get the bolts in all the way. They stick out about 1/4" on each side. I am using a socket wrench, and I twist the lever and push on the back but it keeps coming out of the bold. I don't want to strip the screw, so I am not sure what I should do. Any suggestions?
Thanks! :help:
There is a left and a right, with an L and R. Make sure they are not reversed. If that does not work then try the bolt when there is no insert in the hole.
I got it, the spinlocks weren't in correctly, and I had to tap and drill into the passenger side to remove the stripped bolt.
Edited by rick3000
