Looks like it is the same part number.
You might double-checking any mounting differences with your dealer.
I think the seal to the front windshield is different.
Thanks Loren, I'll do that.
Just wondering, does a 996 hardtop for my 2002 and later fit a 997? Anyone know? Thanks.
Everything I have seen points to that. The hardtop on my 997 carries a 996 part number. I recall some discussion early on with respect to the 997 that it was a complete makeover from the 996 except for the roof. Perhaps they really did mean the hardtop roof.
Of course, you will have to spend a few bucks to install the intallation kit into your unprepared 997, unless it came with one.
Dan
06 997S Hardtop Cab
The only issue you will face with using a 996 hardtop on a 997 is:
The 996 hardtop will probably have the older style "Pin" latch for the rear attachment points. The 997 will not have any mating latch mechanism installed.
You will have to purchase and install the updated threaded bolt rear attachment mechanism on the top and the car. Refer to TSB 6117 for more details. It is a simple modification to do.
Here is a picture of the new and the old attachment methods.
The other minor issue is that the front alignment pins on the hardtop that fit into the slots on the left and right sunvisor mount in the windshield header have slightly different shapes to them. They will fit, but it is unclear how tight the fit will be.
Other than these 2 issues it is PnP.
  • 8 months later...
Did you ever try the 996 roof on 997. I'm in the same situation now looking for hard top.
thanks
  • 2 years later...
thanks
Hi, I've got myself a 996 2004 hardtop, does anyone know the part numbers required to change the mounts, i want to fit it to a 997 2005?
I think they are the same. I have seen a lot of them listed as 996/997 hard top, which makes me think they do. I do think it depends on whether or not your cabrio was ordered ready for the HT or not.
Here is some info from rennlist.com If you have an account there you can read the Do-it yourself with photos at the link I have provided below.
Good luck!
DC
From Rennlist.com at this link: Click Here
"For those that drive their cars in the cold weather like I do, I wanted to have a hardtop to install on my 06 C2S cab in the winter. I'm one of those unusual people that actually like the look of the hardtop!
Unless your 997 was ordered with a hardtop (very rare), in a likelihood, your 997 does not have the mounting hardware on your car to install a hardtop, unlike all of the 996's.
There are many people who question whether a 996 hardtop will fit on a 997. The answer is YES. All that's required are the mounts that bolt on to the car that receive the locks on the top. Mounts are specific to the locking pins on the car. Mounts are left - right specific with the left mount having the electrical connection for the rear defroster included. Electrical hookup is plug and play as the 997 includes the harness for the defroster connection.
It is important to know what kind of hardtop you have, because sometime during the 996 lifespan, the attachment mounts, and hardware on the top, were changed out for a better design. I was lucky enough to find a very CHEAP 996 hardtop with the later mounting hardware.
The parts you will need for the newer style mounts are :
996.561.653.04 (mount to attach to the car)
996.561.654.04 (mount to attach to the car)
900.378.173.09 (8 of these just to be safe)
I bought these mounts and hardware for a total of $245 from my local dealer."
  • 2 months later...
