Replaced the battery and do not have the radio code to unlock the radio. Dealer does not have the code. I would like some help in finding the code for my 2002 boxter S, becker 4462 SN 25011164 manual trans, USA car.
ALS
thanks I will try 8288. the dealer Previously I tried 8290 and that does not work. is there a website or something that has multiple codes for this radio? This is the serial number from the display.
ALS
If the codes did not work then it could be the serial number is wrong.
If the serial number is right and the codes don't work then you will need to see a dealer or Becker.
Loren,
upon checking that is the correct SN obtained from holding down the TP button and shifting through the menu with the right knob. Well I guess something is not right with it.
thanks
als
Edited by niceinms
Loren,
Before I make a trip to the dealer I decided to go to the Becker website and have a look. for a 2002 boxter they have the radio listed as a CDR220(6625) but mine is a CDR220(4462) which is listed for a 2001 Boxter. Maybe I got a previous year radio in my car? Does this make a differnce in the codes?
ALS
