I noticed that there are few posts about the replacement of the generator in the Boxster forum. After reading the info that was available I went ahead and did the job. I must say that the steps that were posted are accurate except that after loosening and removing the bolts, you must first unseat the rightside of the generator from the U-Shaped metal bolt sleeve by prying gently upward. After this you can then rotate the whole genrator to the right for removal.
Hope this helps!
