Part numbers for the above for MY 2001 986 S manual 86.20 transmission?
I checked PET but I am confused as to the exact type and #
Thank you
Edited by renos
On a RoW MY01 Boxster S the taper roller bearing is different on each side of the pinion shaft.
Item 5 and item 6.
999.059.066.02 taper roller bearing (item 5)
999.059.064.00 taper roller bearing (item 6)
Item 5 and item 6.
Thank you
