Retract the steering column too the max.
Turn the steering wheel 90° too the left
Insert a flat screwdriver in too the hole on the back of the steering wheel till he hooked after a steel spring
Push the screwdriver in the direction of the steering column, while pulling on the airbag module
Turn the steering wheel 180° to the right and do the same handling in the other hole
Remove the airbag module and the connectors
Remove the center bolt in the steering wheel
Remove the steering wheel
I hope it's helps
I hope it's helps
PS make sure airbag doenst deploy in Face
:P
just kidding but i would feel safer disconnecting the battery
