post-9461-1182003959_thumb.jpgHi chaps,
I'm trying to fit a B&M short shifter and every gone fine except I dont know how to remove the gear knob and leather cover from the stick??
Any help/advice greatly appreciated.
thanks
Neil
I don't set a set screw for the shift knob so it must be a pull off one.
You need to twist and pull the knob to get it off. The knob is usually pretty tight - so this would have been easier if if was done when the shifter was still assembled.
