I dont know if the bulb frame on a 986 and 966 are similar but if they are, i had the same issue, its the metal contacts being pulled out of the plastic frame due to the tension from the bulb contact that pushes the bulb upwards, I had to zip tie the metal contacts against the plastic frame to keep them from raising out. Now the one bulb that would turn off, never turns off.
Edited by CJ_Boxster
