Just got the smoked led brake light from carnewal, however had to swap out the wires for the light on the wing. While doing doing so I broke the plug, do I have to buy a new wiring harness or can I just install the lose wirings with out the fear of shorting somthing out.
Murphy told me if you don't insulate them from each other they will short out!
Can i buy just the plug and if so whats the part number?
I have a 996 wing lying around from an aftermarket install, I can check for you. Can you be more specific - was it the plug inside the wing or the plug that connects everything (fan included) to the car?
Edited by John Jones
Its the plug that plugs into the brake light on the wing..
Let me know thanks.
