The engine temperature on my 1999 2.5L Boxster seems to be running a little higher than I remember. It has been running in the 190 F to 200 F range. Does not seem to really matter much as to the outside air temp. Is this normal for the 2.5L? What are some temps other owners normally see their 2.5L run at.
Actually great topic. I have a same questions!!!
I've got Boxster 2.5l and my temp is always around middle of the 180 number. I live in Florida and air temps are around 90 F. When I drive it hard temp is going the end of zero, but never pass it.
I was thinking that my car is overheating so I remove bumper and clean the radiators. Still the same. I had cooling tank replaced 8 months ago. I will try to open the valve to remove maybe more air from the cooling system (if there is any).
Is the temp ok?
How about other owners?
Mine usually runs between the "8" and the "0" in 180F on our terribly vague analog gauge. I have seen it above the "0" once on a long spirited hillclimb with air temp about 95F.
I have a 2000 2.7L. It has for the most part always ran just above 180 (needle just past the "0"). I tried to calculate that to be 187F.
There have been at times that the temp has gone above that spot and only in the past couple of years.
sometimes when I sit in rush hour traffic on a hot day.
AND
when I was low on coolant.
Low on coolant I would have thought would not make a difference, but the temp started rising (to around the 200F mark) and the red indicator light on the Temp gauge started flashing. Again, while I was sitting in bumper-to-bumper traffic. I called my Independent Porsche Mechanic and asked his advise. He said the coolant was low.
I hope that helps.
AND
I hope that helps.
Yea mine will go from middle 180 to just about end of 0 then the fans come on and cool down to just above the 0 in street driving. freeway its just above middle .
If you're concerned with your engine getting a bit warmer than usual - check your coolant level. The more coolant there is, the more capacity to absorb heat there is.
Also consider removing your front bumper skin and cleaning out the radiators. Those puppies can get dirty, and particle matter in there insulates, reducing the ability of the radiators to lose heat like they should.
